Hardware problem
Older computer had windows 2000 installed, but it was having a lot of errors. So I backed everything up, and formatted and installed windows 98. Worked great, but needed some tinkering, as all windows installs do.
I installed AV, firewall, and some drivers, did windows updates etc, and now I cannot see the CD-ROM in my computer.
I have attached an image showing the cause of the problem. Anyone have a quick fix?
I am looking for drivers now.
http://english.aopen.com.tw/products/mb/ax6bc.htm post-63-1089985645.jpg
Try going this route;
Controlpanel/ Add-Remove/Windows setup tab/Internet/Details and see if Internet Connection Sharing is checked.
I've also just had the CD drives blink off after a 98 install. The mobo (same chipset as yours) needed the drivers installed for the onboard sound in order to activate the CD-ROM controller- Dual Fifo.
