UPS
moon
OK ...Ill bite ...how do you know that there is a difference ?
Do you only perceive a difference in order to expunge the guilt of spending your money on yet another useless computer gadget on your self .... When you could have taken the other half out for a good time ..... ?
eh eh ...eh eh ....?
Ive got drawer fulls of crap, going back to a still working rubber keyboarded 48k spectrum ....
heh
:D
KEBO 1200D
Well, bearing in mind that a power cut while your hard-drive is working will, at the very least, damage the substrate and give you a 'bad sector' you'd clearly rest easier if it couldn't happen. With a UPS you can even set the slow-shutdown to give you time to save your files or you can set it automatic and it saves them for you.
In my case, Rosi's PC, the one I built for here at WF, is necessarily on the same circuit as a fridge. I found that the power drain caused when the fridge kicked in was affecting her RAID array. I had to periodically rebuild the mirror. The UPS has sorted that, providing a smoothed suppy no matter what happens to the mains. I could go on, but I'm beginning to taste spam. :D
