JaveW Posted September 15, 2004 Report Share Posted September 15, 2004 Hey peoples.I have such a weird problem.When I try to burn a DVDR or erase a DVD-RW i get errors.I make use of a Shuttle XPC SN41G2 with AMD Athlon 3Ghz 512 MB 200GB disk and my burner is a Pioneer DVR 107D.I've had this problem for over a half year now and I really had enough of it. Before I had the Pioneer 106 when the first time this problem occured that's why I bought back then the 107D but still exactly the same problem.When I burn a DVDR windows freezes up. sometimes at 10% sometimes at 90% so somewhere it just freezes.DVD-RW won't help neither, My explorer says free sapce 4.38Gb but when I try to burn something on it the software tells me to erase the DVD-RW first, and when it erases then at 100% it gives me an I/O error.So I tought ok, the new 107 exactly the same problem. Never had this before.I used the Datawrite DVDR discs to burn 4x speed. They worked really good in the beginning. But now not anymore.Now when I look in my system log it gives \Device\CdRom0, has a bad block.Now I've reinstalled Windows Xp, tryed like everythign and still same problem.The funny part is, I can burn Cd's without any problem.Now what is going on?Anybody that can help me pls?Jave Quote Link to comment Share on other sites More sharing options...
AlanHo Posted September 15, 2004 Report Share Posted September 15, 2004 My DVD Burner manual says that I need a minimum of 5 GB's of free space on the hard drive - preferably 10 GB.It seems that this may be your problem - with DVD's you don't have enough space on your hard drive to store the temporary file whilst writing. Quote Link to comment Share on other sites More sharing options...
-pops- Posted September 15, 2004 Report Share Posted September 15, 2004 What burning software are you using?What DVDs are you burning? Data, Audio, Video? Quote Link to comment Share on other sites More sharing options...
madboy33 Posted September 16, 2004 Report Share Posted September 16, 2004 JaveWMaybe the firmware needs updating on the burner?http://www.pioneer-eur.com/eur/support_sof...ware#fdvdwriterLook down the list and you will see firmware for the DVR-107D I must tell you though, if you do not upate the firmware correctly,then the drive may become unusable Quote Link to comment Share on other sites More sharing options...
