AlanHo Posted September 18, 2004 Report Share Posted September 18, 2004 In Outlook 2003 I am having a problem adding a zip file attachment to an Email message.I click on the paper clip which opens an Explorer type window showing my various folders, browse to the required folder and can see there a list of all the files - except that all files with zip extensions are not shown. They are there but hidden from view - I can see them in Explorer - but not in the Outlook attach files window.To add a zip attachment I am having to drag and drop the file from Explorer to the Outlook paperclip.EDITI restored back a couple of weeks and all is now OK. Quote Link to comment Share on other sites More sharing options...
spikeychris Posted September 18, 2004 Report Share Posted September 18, 2004 Theres no reason why Outlook should not see a zip file. Did you have password protected it, them? Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted September 19, 2004 Report Share Posted September 19, 2004 Very strange Alan. Good thing you have system restore. Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted October 15, 2004 Report Share Posted October 15, 2004 This probably won't be helpful, but make sure your File Types at the bottom of the attachment window is set to All Files. I can't imagine that it wouldn't already be set to that, but it sounds like you weren't seeing a particular type of file?Sincerely, Quote Link to comment Share on other sites More sharing options...
