kkazakos2003 Posted September 24, 2004 Report Share Posted September 24, 2004 Hi,I have winxp pro SP1 and I have the following problem-->When I try to access the internet through my modem (a Best Data Data Fax modem of Crypto) the session timeouts and the following message appearsError 777 : The connection attempt failed because the modem on the remote computer is out of order.Windows recognizes the modem and the its driver is installedWhat is the problem???ANy solutions???thanks :) kostas Quote Link to comment Share on other sites More sharing options...
andsome Posted September 24, 2004 Report Share Posted September 24, 2004 WELCOME to WF. Some of the clever people will be at work now, so be patient, I have no doubt that you will have your problem solved. Quote Link to comment Share on other sites More sharing options...
-pops- Posted September 24, 2004 Report Share Posted September 24, 2004 Error 7771. The modem isn't working. If external, powercycle it, if internal, reboot the computer.2. Make sure the modem is plugged in securely. This includes external cables, and the PCI or ISA slot seating if internal.3. Make sure the computer is not trying to dial multiple connections, that it has no fax software, etc using the modem.4. Reinstall the modem.From http://www.modemhelp.net/dunerror/error_777.shtmlAlso:Error 721," "Error 678," "Error 691," or "Error 777" error message when you try to establish a dial-up connection after you upgrade to Windows XPFor explanation click here Quote Link to comment Share on other sites More sharing options...
