lroberts Posted October 3, 2004 Report Share Posted October 3, 2004 i have recnetly bought a set of 5.1 medion speaker but the sub woofer does not come on whne i play music i have tried all teh differetn configerations for it and it still does not come on.does anyone have any idea why?thanks Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted October 3, 2004 Report Share Posted October 3, 2004 I have a 3 piece set, 2 satalites and a sub. The sub is powered, and the satalites stem from it, with another cable comming from the computer. The sub has an on/off button which must be on for the speakers to work at all, it also has a volume control. Check for these things.Also, if your running Windows XP;Click Start -> Control Panel -> Sounds and Audio Devices.Under the Volume tab, Click Advanced (under Speaker settings, not Device Volume), and set it to say 5.1 Surround Sound Speakers.Also click the advanced under Device Volume, Options -> Advanced Controls. Click advanced here and make sure the bass is up to about half, or a comfortable level.If none if this works, you may need drivers.Post back if you need further help. Quote Link to comment Share on other sites More sharing options...
-pops- Posted October 3, 2004 Report Share Posted October 3, 2004 It may be, as well, that the sub woofer is faulty. Quote Link to comment Share on other sites More sharing options...
