jtimmy Posted October 25, 2004 Report Share Posted October 25, 2004 Computer keeps rebooting after about 10 mins of gamming or encoding here is the info contained in the error message "Windows has recovered from a serious system failure"the following will be included in the report "C:\WINDOWS\Minidump\Mini102204-03.dmpC:\DOCUME~1\TIMMY\LOCALS~1\Temp\WER1.tmp.dir00\sysdata.xml" was wondering could this be a memory issue or what any help would be usefull. Quote Link to comment Share on other sites More sharing options...
-pops- Posted October 25, 2004 Report Share Posted October 25, 2004 This any help?http://support.microsoft.com/default.aspx?...kb;en-us;318023 Quote Link to comment Share on other sites More sharing options...
jtimmy Posted October 26, 2004 Author Report Share Posted October 26, 2004 Thanks for the info i downloaded the drivers like you said but when i tried to install i got this message "C:\WINDOWS\SYSTEM32\AUTOEXEC.NT. The system file is not suitable for running MS-DOS and Microsoft Windows applications. Choose 'Close'to terminate the application." any ideas? TIA Quote Link to comment Share on other sites More sharing options...
-pops- Posted October 26, 2004 Report Share Posted October 26, 2004 I am working blind here. A remedy is given in MSKB 324767:http://support.microsoft.com/default.aspx?...kb;en-us;324767Perhaps someone else knows about this? Quote Link to comment Share on other sites More sharing options...
jtimmy Posted October 26, 2004 Author Report Share Posted October 26, 2004 Thanks for all your help and info although i could not get the drivers to install i did get my hands on another driver thats supposed to be compatible withe my video card will keep you informed again thanks for all your help. Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted October 26, 2004 Report Share Posted October 26, 2004 http://www.driverguide.comYou need an account, but it's free. Quote Link to comment Share on other sites More sharing options...
Cpt James T. Kirk Posted October 26, 2004 Report Share Posted October 26, 2004 thats not a bad site at all scarecrow. they even have a driverguide toolkit you can d/ld that when ran searches your computer for everything thats installed and just clicking on it can lead you to the link, when online, to look for any driver for any device you got. unfortunately though, the toolkit is a limited time thing then you have to purchase it. but using it at first is all he shouls need to get the drivers needed. Quote Link to comment Share on other sites More sharing options...
jtimmy Posted October 26, 2004 Author Report Share Posted October 26, 2004 Great site have installed the drivers, got my fingers crossed will keep you all updated thanks for the quick responses and the valuable info. Quote Link to comment Share on other sites More sharing options...
bvw Posted October 26, 2004 Report Share Posted October 26, 2004 Good luck :) Quote Link to comment Share on other sites More sharing options...
