madboy33 Posted November 3, 2004 Report Share Posted November 3, 2004 Hi all I have system mechanic 5 and have found that if i go to defrag the RAM a box pops up saying Unable to locate the "Processor" Performance object (see screenshot below)I have unistalled it, deleted the programme folder and used regscrub to delete all registry entries. Re-installed and exactly the same thing happensAny Ideas Quote Link to comment Share on other sites More sharing options...
Chris Posted November 3, 2004 Report Share Posted November 3, 2004 Start, Run, Type:perfmonClick OK.See if you can something to do with processor...time?Just a guest. Quote Link to comment Share on other sites More sharing options...
-pops- Posted November 4, 2004 Report Share Posted November 4, 2004 Does your computer run as it should?If it does, forget about what these panicware programs tell you and use your computer for something more constructive :) Quote Link to comment Share on other sites More sharing options...
madboy33 Posted November 4, 2004 Author Report Share Posted November 4, 2004 popsrather than a re-boot i used to just defrag my ram Quote Link to comment Share on other sites More sharing options...
