artist Posted December 8, 2004 Report Share Posted December 8, 2004 I have lost the connection from scanner to PC - the printer, fax copier is fine.I did a couple of system restores - back on November 4th all worked fine. The problem with that is that AVG is no good - wrong language error, it says. I can't remove AVG to reinstall - just keep getting the error. Too far back I guess.With the system up to date - a troubleshooter for the printer says to reinstall the scanner - but when I put the disc in, I get a message saying it isn't compatable with my system.If I take out AVG before doing a restore, will that work or will it just put back the old AVG.If I go back to when the printer is ok, what will happen if I remove that then - and then come up to date again?It's a 950 series HP combination printer. I am on XP home. Quote Link to comment Share on other sites More sharing options...
bvw Posted December 8, 2004 Report Share Posted December 8, 2004 http://welcome.hp.com/country/uk/en/support.htmlI recently went to the HP site and installed updated drivers for my old 840c, they worked a treat.Might be worth a try artist :flowers: Quote Link to comment Share on other sites More sharing options...
artist Posted December 8, 2004 Author Report Share Posted December 8, 2004 I did that already - they were fine............. :( Quote Link to comment Share on other sites More sharing options...
djohn Posted December 8, 2004 Report Share Posted December 8, 2004 Hi artist,With your system at its current date [Today] remove AVG then restore to Nov. 4th. If I read your post right, the scanner should then work, if so leave at that restore point and re-install AVG. Don't bring back to current date as that will just alter everything back to how it is now. :) Quote Link to comment Share on other sites More sharing options...
artist Posted December 9, 2004 Author Report Share Posted December 9, 2004 Thanks djohn - it was logic I wanted and you seem to have clarified it - I hopeI'll have a go at that when I'm properly awake and alert. :rolleyes: Quote Link to comment Share on other sites More sharing options...
artist Posted December 9, 2004 Author Report Share Posted December 9, 2004 Seems to have worked a treat! :flowers: :) Quote Link to comment Share on other sites More sharing options...
doug Posted December 9, 2004 Report Share Posted December 9, 2004 And only 2 hours to become fully awake and alert! Quote Link to comment Share on other sites More sharing options...
djohn Posted December 9, 2004 Report Share Posted December 9, 2004 Your welcome artist, only too pleased it worked for you. :) Quote Link to comment Share on other sites More sharing options...
