ike Posted December 24, 2004 Report Share Posted December 24, 2004 When I'm on certain websites, and open up twoor three pages at once.....I sometimes get thiswarning.IEXPLORE caused a general protection faultin module USER.EXE at 0003:00006d4f.Registers:EAX=00000000 CS=17af EIP=00006d4f EFLGS=00000202EBX=04045ce4 SS=45df ESP=00000002 EBP=00000000ECX=bfc00000 DS=16b7 ESI=00000000 FS=2137EDX=6b040000 ES=5e37 EDI=00020000 GS=0000Bytes at CS:EIP:ca 08 00 b8 b7 16 55 8b ec 1e 8e d8 66 33 c0 66 Stack dump:00000000 00000000 00000010 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 What does it all mean ?I have to close out and start all over..I run Win98 se Internet Explorer 6 Quote Link to comment Share on other sites More sharing options...
-pops- Posted December 24, 2004 Report Share Posted December 24, 2004 Has this happened only recently e.g. after a recent change to your computer - an upgrade of Internet software (I.E. 5.x to I.E. 6).Does this happen with other browsers e.g Firefox? You might wish to download an alternative browser to try it.Personally, I almost never use I.E. any longer, much preferring Firefox which is faster and more stable on my machines. Quote Link to comment Share on other sites More sharing options...
spikeychris Posted December 24, 2004 Report Share Posted December 24, 2004 Because this happens when you have more than one page at a time open and the register line 'EAX=00000000 CS=17af EIP=00006d4f EFLGS=00000202' is displayed you could have a cache or cookie problem. Export your cookies usingfile/import and export or just delete them. Then as you are using Win98 restart and boot to DOS. Run the following commands from the windows directory IE: c:\windows\>smartdrvdeltree historydeltree tempor~1deltree cookiesReboot with Ctrl Alt Delete and see if you can open more that one page again. Don't run the above commands if you have recently installed a program and have not yet rebooted. Quote Link to comment Share on other sites More sharing options...
ike Posted December 26, 2004 Author Report Share Posted December 26, 2004 Well some more faults...I don't have something set right...but what ?(#1)IEXPLORE caused a general protection faultin module USER.EXE at 0003:00006d4f.Registers:EAX=00000000 CS=17af EIP=00006d4f EFLGS=00000202EBX=04045ce4 SS=45df ESP=00000002 EBP=00000000ECX=bfc00000 DS=16b7 ESI=00000000 FS=2137EDX=6b040000 ES=5e37 EDI=00020000 GS=0000Bytes at CS:EIP:ca 08 00 b8 b7 16 55 8b ec 1e 8e d8 66 33 c0 66 Stack dump:00000000 00000000 00000010 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000 0000000000000000 00000000 00000000 00000000===============================================(Same as #1 above except) Registers:EFLGS=00000206EBX=05f96fac SS=4bcf ECX=bfc00000 FS=4817 ES=4e27 ===============================================(Same as #1 above except) Registers:EBX=0455848c SS=56af FS=759f ES=3b47 ===============================================(Same as #1 above except)Registers:EBX=028a7714 SS=127f FS=628f ES=475f ===============================================(Same as #1 above except)Registers: EFLGS=00000206EBX=045f66cc SS=0fe7 FS=3cdf ES=0f87Stack dump:00000000 00000000 00000010 00010000 00010000 70000000 6034c1bc 2bc0045f 0fe7bff9 01878052 3fc50000 4da0bff9 19b8453a 8078bff7 eb1c045f 186d045f ===============================================(#2) While playing the game on my desktop.....FREECELL caused a general protection faultin module FREECELL.EXE at 0001:00003de2.Registers:EAX=006e0000 CS=61af EIP=00003de2 EFLGS=00000246EBX=17bf0002 SS=61a7 ESP=00001cb8 EBP=00001cbcECX=04257348 DS=61a7 ESI=00000312 FS=0f27EDX=16d70000 ES=0133 EDI=00000312 GS=0000Bytes at CS:EIP:ff 1e 06 03 1e c5 16 5a 02 b8 00 25 2e f7 06 3c Stack dump:00003db9 3add1cc2 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 1cec1ce1 1ce0000a 00001da4 1d1c1ce1 00000000 1ce00005 Hey spikeychris....I'm not to familiar with DOS. These directions you gave, won'tcause me to have to reformate or anything will it ? Thanks Ike.. Quote Link to comment Share on other sites More sharing options...
scuzzman Posted December 27, 2004 Report Share Posted December 27, 2004 No, all it does is delete your temp files...But, these errors are being caused by something writing over crucial OS code in your RAM... when is the last time this system was reformatted? Quote Link to comment Share on other sites More sharing options...
ike Posted December 27, 2004 Author Report Share Posted December 27, 2004 when is the last time this system was reformatted?Sometime around 1998 or 1999 Quote Link to comment Share on other sites More sharing options...
scuzzman Posted December 27, 2004 Report Share Posted December 27, 2004 Make sure you're running anti-spy, anti-virus, etc on your computer, and with the latest definitions. These can often cause this problem. With the frequency that this is occuring though, while I'm not reccomending you do it, I would backup, reformat, and reinstall. Quote Link to comment Share on other sites More sharing options...
