Chris Posted January 1, 2005 Report Share Posted January 1, 2005 My DG834G routers statistics page shows additional information [ADSL Statistics added] after an upgrade of the firmware InfoI can't find anything which explains Line Attenuation / Noise Margin. Would anyone care to confess? Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted January 2, 2005 Report Share Posted January 2, 2005 Line attenuation is the loss of signal over distance. Not sure what Noise Margin is. I also don't believe those new stats will be of much use for home. :)Sincerely, Quote Link to comment Share on other sites More sharing options...
spikeychris Posted January 2, 2005 Report Share Posted January 2, 2005 Worth a look Quote Link to comment Share on other sites More sharing options...
spikeychris Posted January 2, 2005 Report Share Posted January 2, 2005 The higher the noise margin, the better. As I understand it, the noise margin is basically how much louder the signal is than the background noise. Its a diag option, the higher that number, the stronger your signal.If you were in the low range then moving halogen lights away from the router and Routing the phone cable from from electrical devices and using shorter cable could help. Quote Link to comment Share on other sites More sharing options...
Chris Posted January 2, 2005 Author Report Share Posted January 2, 2005 I'm on a 25M Cat5e here... :(But I ain't moving again :DI've got no problems [touch wood].... yet. Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted January 3, 2005 Report Share Posted January 3, 2005 Etherenet's supposed to be good for 100m, so you should be fine with that. :) Quote Link to comment Share on other sites More sharing options...
scuzzman Posted January 3, 2005 Report Share Posted January 3, 2005 Line attenuation is essentially loss of packets/signal over x distance, where x is the number, in feet, you are from the CO. Your Noise Margins are the ratio of electronic signal mixing (line noise) in decibels, to the signal strength. The NM's should stay between 6 and 31, 6 being bare minimum, 9 is preferable. Higher is better.Attenuation can be between 0-60 and it'll be acceptable, lower being better. Quote Link to comment Share on other sites More sharing options...
scuzzman Posted January 3, 2005 Report Share Posted January 3, 2005 And actually HCA - those stats are great for diagnosis of problems. General rule of tumb is this:if you have very high attenuation (80-100), and low bitrates and low noise margins (0-6) this indicates a potential problem with one/all of the following: unfiltered device, phone line between dsl modem and jack > 14', bad filter, internal wiring grounding out, improper internal wiring, high-frequency devices (moniter, speaker, halogen lamp/light, etc) around/near modem or dsl data line. It can assist in essentially debugging an intermittent sync issue. ie: change a filter, check results, repeat. I'll admit: I'm a tier 3 network and escalation specialist for a very prominent U.S. DSL ISP. Corrected spelling and added more info Quote Link to comment Share on other sites More sharing options...
