Netzero High Speed Not Working!!!!!
tony-fr-si
Can anyone shed some light on my problem - i.e., I'm been using netzero high speed ISP for the last 12 months. When surfing the internet, the system runs very slow. I have tried using different dial-up numbers to no avail.
I'm using gateway Pentium ® 4 CPU 2.60 GHz, 2.59 ghz, 496 mb of ram, XP Pro with service pack 2. 80 gigabytes on the C:\ drive
Any help is appreciated.
tony-fr-si
It is not quite clear from your comments if your operating system is slow, or your Internet connection.
If your system is slow, have you tried Ccleaner and disk defrag? Also check for spyware using Lavasoft Ad-aware or Microsoft's new AntiSpyware ?
If your connection is slow, what is the supposed and actual connection speeds?
Yes - I run the following programs daily:
a) - Window washer used to delete all temporary files, cookies, and much more.
B) - Spysweeper used to remove spyware.
c) - Norton Anti-virus sweeping all files/folders on the C: disk.
d) - Run disk defrag once a week.
Still not clear: your system is slow, or your Internet connection is slow? Or, as you wrote in your initial post, your system is slow when surfing the Internet?
If the latter is the case, that would indicate that the driver for your modem/router may not be ideal.
What browser are you using?
