persianpower Posted January 11, 2005 Report Share Posted January 11, 2005 HI can you guys please help me tweak/repair my connection?when im browsing, I have this 5 second lag between web pages. The progress bar at the right bottom corner of IE stolls as it goes from one page to the next. Im forced to hit refresh to get it going again (though not always). Sometimes the speed is super fast (especially visiting sites like Google.ca for some reason).I have DSL (always connected) with TELUS VELOCITY in Canada. I usually download from anywhere between 40-150Kb/sec (though usually closer to 40) I believe my service provicder promised closer to 300kb/sec. Im running WINDOWS XP PROHere are my TCP/IP Analyzer results (after I followed all of Dr. Tweaks modification advice, which can be read by visiting this link) http://forums.speedguide.net/showthread.php?t=73799TCP options string = 020405b40103030001010402 MTU = 1500 MTU is fully optimized for broadband. MSS = 1460Maximum useful data in each packet = 1460, which equals MSS.Default Receive Window (RWIN) = 64240 RWIN Scaling (RFC1323) = 0 bits Unscaled Receive Window = 64240 RWIN is a multiple of MSSOther values for RWIN that might work well with your current MTU/MSS: 513920 (MSS x 44 * scale factor of 8)256960 (MSS x 44 * scale factor of 4)128480 (MSS x 44 * scale factor of 2) bandwidth * delay product (Note this is not a speed test):Your RcvWindow limits you to: 2569.6 kbps (321.2 KBytes/s) @ 200msYour RcvWindow limits you to: 1027.84 kbps (128.48 KBytes/s) @ 500ms MTU Discovery (RFC1191) = OFF Time to live left = 53 hopsTTL value is ok. Timestamps (RFC1323) = OFF Selective Acknowledgements (RFC2018) = ON IP type of service field (RFC1349) = 00000000Here are my current TCP/IP Registry settings (pulled from Cablenut console)*note* empty does not mean zero* just blankDefaultReceiveWindow 64240DefaultSendWindow = emptyDisableAddressSharing = emptyInitialLargeBufferCount = emptyInitialMediumBufferCount = emptyInitialSmallBufferCount = emptyLargeBufferSize = 8192MaxFastTransmit = empty MediumBufferSize = 3008 PriorityBoost = emptySmallBufferSize = 256 TransmitWorker = 32 FastSendDatagramThreshold =empty EnableFastRouteLookup = emptyEnablePMTUDiscovery = 0IgnorePushBitOnReceives = empty GlobalMaxTcpWindowSize 256960MaxFreeTcbs = empty MaxHashTableSize = empty MaxNormLookupMemory = empty SackOpts = 1 SynAttackProtect = empty Tcp1323Opts = 1TcpLogLevel = emptyTcpMaxDupAcks = 2TcpMaxHalfOpen = empty TcpMaxHalfOpenRetried = empty TcpRecvSegmentSize = emptyTcpSendSegmentSize = emptyTcpTimedWaitDelay = empty TcpUseRFC1122UrgentPointer = 0 TcpWindowSize = 256960MaxConnectionsPer1_0Server = 20 MaxConnectionsPerServer = 10 by the way i downloaded a file from the Roadrunner FTP site (speed test)I jumped into the download around ~150kb/s but kept falling till i reached around 80kb/sec at the middle. Then i cancelledHope that helpsIm looking forward to hearing any and all advice you guys can sharethanks in advance Quote Link to comment Share on other sites More sharing options...
-pops- Posted January 11, 2005 Report Share Posted January 11, 2005 Have you tried using an alternative web browser?I use Firefox as my main browser now - IE almost never gets a look-in.Give it a go, there's nothing to lose. Firefox has the reputation of being faster than IE in any case.Firefox Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted January 11, 2005 Report Share Posted January 11, 2005 persianpower,This honestly sounds much more like a spyware issue than a networking issue. Are you familiar with spyware removal programs like Spybot Search & Destroy, and Ad-Aware, and do you use them and update them?Sincerely, Quote Link to comment Share on other sites More sharing options...
persianpower Posted January 11, 2005 Author Report Share Posted January 11, 2005 umm i know about spyware pretty well . i can pretty much guarantee i have a clean comp. I was hoping you guys were familiar with DSL Connections and tweaking?????????I believe i have a wrong tweak in place, i just need someone familiar with the above settings to guide me to reset them for optimal use (as stated above)thanks guys Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted January 12, 2005 Report Share Posted January 12, 2005 I can't know whether you're familiar with spyware or spyware removal until I ask. Thanks for clarifying.I'm not familiar with Dr. Tweaks tweaks. If you didn't change anything on your PC, and your download speeds decreased, I'd check with the ISP. You're supposed to be guaranteed dedicated bandwidth from DSL providers, I believe, unlike cable which is more like an Ethernet LAN.My personal view is to untweak, do an extended ping with large packets (ping -t www.cisco.com -l 200), and see how much packet loss you get. If you get packet loss, call TELUS VELOCITY.There may be other moderators who know the tweaks. :) Quote Link to comment Share on other sites More sharing options...
scuzzman Posted January 12, 2005 Report Share Posted January 12, 2005 I concur with HCA on this one...DSL gives you an exact amount of band, that you should never under normal circumstances go under. It should defintely never fluxuate in this fashion. Undo the tweaks, and see if it still does it. If so, contact your ISP. Quote Link to comment Share on other sites More sharing options...
persianpower Posted January 12, 2005 Author Report Share Posted January 12, 2005 my friends the problems was never downloading speeds that is pretty fixed between 40-150kb/secTelus has quoted me a max of 150kb/secI usually hover between 40-150 (more often closer to 40 than 150)is this normal?The PROBLEM im having is webpage browsingi have a lag of a few seconds between commmon web pagesive untweaked Quote Link to comment Share on other sites More sharing options...
scuzzman Posted January 12, 2005 Report Share Posted January 12, 2005 my friends the problems was never downloading speeds that is pretty fixed between 40-150kb/secTelus has quoted me a max of 150kb/secI usually hover between 40-150 (more often closer to 40 than 150)is this normal?The PROBLEM im having is webpage browsingi have a lag of a few seconds between commmon web pagesive untweakedThese problems could be, and most likely are, related. I'm a tier 3 network and escalations specialist for a DSL ISP, and I can tell you that your bitrates should never never fluxuate that much. Also - 40-150kbps is very very low for DSL. Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted January 12, 2005 Report Share Posted January 12, 2005 persianpower,I suspect something's bogging your PC down. Do the pages load normally after the delay, or is page loading slow too? It sounds like you know your way around a PC pretty well. Have you checked Task Manager, or used any utilities to see whether there is anything strange running, or taking up a lot of processor time when you're connected to the Internet?You can also look in Add/Remove Programs for any suspicous programs and remove them. Using regedit, you can go to Hkey_Local_Machine\Software\Microsoft\Windows\CurrentVersion\Run, and see if there are strange programs in there.MSCONFIG is a useful utility for turning off unneeded programs from startup. You should be able to go to Start, Run, and type in msconfig. Go to the Startup tab in the System Configuration Utility and uncheck anything you don't recognize. You can do a quick Google search for things you're unfamiliar with in there.I get the opportunity to work on a lot of corporate and home PC's, and I always begin with antivirus and spyware removal when people describe the symptoms you have. If those don't resolve the problems, I start to scrutinize what's running. It sounds like you've already done that, but maybe another look around will help? Would you be able to post a HijackThis log?If you feel like I'm sending you down the wrong path, please PrivateMessage or post. I'm honestly trying to help. :) Quote Link to comment Share on other sites More sharing options...
Vasichko Posted January 12, 2005 Report Share Posted January 12, 2005 SpyBot Search & Destroy...Get it...use it...I believe it is a blessing sent down from God to help us all, it rox!!! Quote Link to comment Share on other sites More sharing options...
