Problems with my cd drive
keelo1027
CD drives are far from being robust, so much so that the ones for desk top machines are considered to be almost disposable items. Laptops are a little different in that, whilst being just as, or more, delicate, they are more difficult to replace.
I would follow the advice already given and get a professional to have a look at/replace it. Laptops are definitely not for do it yourself repairs..
Windows will do it automatically - if it's in device manager, Windows took care of it.
If it's not, run the Add hardware wizard from Control Panel, you may need the CD's that came with the computer, or you can download the drivers.
If it is listed in device manager, then the drivers were reinstalled, and you've, unfortunately, done all you can :(.
