lordnightmare Posted January 18, 2005 Report Share Posted January 18, 2005 After laser printer configuration, i've worked good only for some prints.In a present, it happens one strange thing: if the adsl modem/router is turned off my printer don't print unless it's turned on.Being my modem also a router, and a firewall, can be this the malfunctioning cause? How can i do to manage ONE TIME FOR ALL THESE PROBLEMS? :angry: Quote Link to comment Share on other sites More sharing options...
Agent Smith Posted January 18, 2005 Report Share Posted January 18, 2005 Hello lordnightmare and welcome to the Forum.Can you tell us what make and model of printer you have, and how is it connected to your computer (usb, parallel or via network). Please try to give as much information as you can.Mr. IM Quote Link to comment Share on other sites More sharing options...
scuzzman Posted January 19, 2005 Report Share Posted January 19, 2005 Also - the make and modem of your modem and whether it's connected through Ethernet or USB? Also - does anything go through a USB hub? Quote Link to comment Share on other sites More sharing options...
lordnightmare Posted January 20, 2005 Author Report Share Posted January 20, 2005 My printer is an HP 2100 TN and is connected by network thru the adsl modem/router Quote Link to comment Share on other sites More sharing options...
scuzzman Posted January 20, 2005 Report Share Posted January 20, 2005 Ummm...If the printer is connected through the router...The router must be turned on before any information will pass through it, hence why the signal is not getting to the printer. Quote Link to comment Share on other sites More sharing options...
