Billw Posted February 9, 2005 Report Share Posted February 9, 2005 Help, I have been trying to install a Belkin Wirless G PCI Network card on the kids computer and the damn thing won't recognize the card.I started with a Netgear card, returned it and got the Belkin. I reformatted the HD, reinstalled 98 and SE to no avail. I have removed every PCI card from the computer and tried the Wireless NIC in all the slots. 98SE still will not recognize the card.Anyone have an idea ?ThanksBillPIII 450128 mb ramwindows 98se Quote Link to comment Share on other sites More sharing options...
expertec Posted February 9, 2005 Report Share Posted February 9, 2005 What model number is the card? Quote Link to comment Share on other sites More sharing options...
Billw Posted February 9, 2005 Author Report Share Posted February 9, 2005 HeyIt's a F5D7000 Quote Link to comment Share on other sites More sharing options...
expertec Posted February 9, 2005 Report Share Posted February 9, 2005 Did you install the card first or the software that came with it? Quote Link to comment Share on other sites More sharing options...
Billw Posted February 9, 2005 Author Report Share Posted February 9, 2005 The software, then the card Quote Link to comment Share on other sites More sharing options...
scuzzman Posted February 10, 2005 Report Share Posted February 10, 2005 When you install the card, does it become listed in Device Manager (even if it's as an unknown device)? Quote Link to comment Share on other sites More sharing options...
Billw Posted February 10, 2005 Author Report Share Posted February 10, 2005 Hey Scuzzman,no it does not show up in device mgr. The add new hardware wizard does not start upon boot up either. I have cleared any and all conflicts with other cards in device mgr. I am geting ready to try a USB wireless NIC and see if that works. Quote Link to comment Share on other sites More sharing options...
scuzzman Posted February 10, 2005 Report Share Posted February 10, 2005 Try a different PCI slot. Quote Link to comment Share on other sites More sharing options...
Billw Posted February 10, 2005 Author Report Share Posted February 10, 2005 I have tried every pci slot on the board. Nothing is working Quote Link to comment Share on other sites More sharing options...
scuzzman Posted February 10, 2005 Report Share Posted February 10, 2005 Try another NIC?Really, that's all I can think could be wrong... if the OS isn't even noticing it.You might try running Windows Update to get the latest OS drivers, then retry it. Quote Link to comment Share on other sites More sharing options...
Billw Posted February 10, 2005 Author Report Share Posted February 10, 2005 Hi, I have tried both the Netgear 54mbps and now the Belkin equivalent and neither is working. I am going to try updating 98SE as much as it will and see if it works. If it doesn't work then I am going to try USB. If that doesn't work then I am out of luck. Quote Link to comment Share on other sites More sharing options...
ric Posted February 11, 2005 Report Share Posted February 11, 2005 I had the same problem. Have you tried other devices in the pci slots? I think a controller or something was fried when I installed mine, nothing worked after that (modem, wireless card, ethernet card). I gave it up and purchased a usb wireless adapter instead, about the same cost and portable! Solution? Maybe, maybe not. Quote Link to comment Share on other sites More sharing options...
