Blue Screen, Frozen System, Switching Accounts
Problem: When two accounts are logged on, ADM & USER, and I elect to switch accounts - the system freezes with a BLUE SCREEN. All keys are frozen. To restart the system, I must keep the power startup button pressed down for a minute or more.
Configuration: Windows XP/PRO Service Pack 2, 512 MBs RAM, 80 GBs Hard Drive.
Software Running: Webroot SpySweeper, Webroot Window Washer, Norton 2005 Anti-Virus.
Free Disk Space: 65 GBs
Thxs..... Tony
Pwillener-
To switch accounts on windows XP/PRO as follows:
1) Click on the START tab.
2) On the Popup window, click on the LOG OFF BUTTON.
3) The log off button opens the Log Off Window which contains (2) buttons: a) log off: provides option for closing your programs window and logging off. b) Or leaving your programs running and switching to another user account.
Pwillener-
3) The log off button opens the Log Off Window which contains (2) buttons:  a) log off: provides option for closing your programs window and logging off. B) Or leaving your programs running and switching to another user account.
Are you able to log off and then log on the other user account?
3) The log off button opens the Log Off Window which contains (2) buttons:  a ) log off: provides option for closing your programs window and logging off. b ) Or leaving your programs running and switching to another user account.
And the blue screen happens with both ( a ) and ( b ) option, or just with one of these?
Your fast-user switching is conflicting with one of your applications.
My reccomendation would be (this might take awhile) is to open all those apps, close one and try it. If it blue-screens, do it again with a different one. If not, you've found the conflicting application... try reinstalling it.
