Help
Ok, i think im in a fix...
I just upgraded to Windows XP from windows 98. Everything went well in the install, but then when i opened up the start menu, there was nothing in the progrmas folder.
The My documents folder either. I then checked the hard drive, and strangely, everythings still there. Also, Windows 98 no longer works.
Does anyone know what to do?
Welcome to the Windows Forum!
I only did one upgrade from Windows 98 to XP, and I had exactly the same result as you had. After that I did only clean installs of XP.
There are many guides on the Internet how to upgrade from 9x to XP, but I ever really read any of them fully.
I cannot help you with your situation, but there are many experienced people around here. So help and advice may come soon.
One question: did you take a backup of your Windows 98 system before (or during) the upgrade?
That'll get all the settings back? ie. All the programs will go back to the start menu etc
No, you will have to reinstall all applications.
Also...Wheres the backup function in windows XP? I can't seem to find it
Open My Computer (or Windows Explorer) -> Properties -> Tools. I believe only XP Pro has a Backup tool.
