Robby1313 Posted March 6, 2005 Report Share Posted March 6, 2005 If I copy data from the Master to the Slave hard drive, or from Slave to Slave it is very slow. My Computer is very slow during the copy. The CPU usage is 100% during the copy.I have checked the settings on the hard drives, they are correctly set to Master and Slave. The IDE channel setting is set to DMA.MS XPPentium 4, 2.8786 MB memoryHard drive IC35L120AVV207-0 (123 GB, 7200 RPM, Ultra-ATA/100) Hard drive Maxtor 6B200P0 (189 GB, IDE, 7200 RPM) I have installed EVEREST: [ IC35L120AVV207-0 ] Device Properties: Driver Description IC35L120AVV207-0 Driver Date 1-7-2001 Driver Version 5.1.2535.0 Driver Provider Microsoft INF File disk.inf Disk Device Physical Info: Manufacturer IBM Hard Disk Family Deskstar 180GXP Family Code Name Vancouver 2 Form Factor 3.5" Formatted Capacity 123.5 GB Disks 2 Recording Surfaces 4 Physical Dimensions 146.0 x 101.6 x 25.4 mm Max. Weight 640 g Average Rotational Latency 4.17 ms Rotational Speed 7200 RPM Max. Internal Data Rate 699 Mbit/s Average Seek 8.5 ms Track-To-Track Seek 1.1 ms Full Seek 15 ms Interface Ultra-ATA/100 Buffer-to-Host Data Rate 100 MB/s Buffer Size 2 MB Device Manufacturer: Company Name Hitachi Global Storage Technologies Product Information http://www.hgst.com/products [ Maxtor 6B200P0 ] Device Properties: Driver Description Maxtor 6B200P0 Driver Date 1-7-2001 Driver Version 5.1.2535.0 Driver Provider Microsoft INF File disk.inf Device Manufacturer: Company Name Maxtor Corporation Product Information http://www.maxtor.com/en/products/ Who can help me?If you want more information, just ask! Quote Link to comment Share on other sites More sharing options...
andsome Posted March 7, 2005 Report Share Posted March 7, 2005 I am not qualified to solve your problem I'm afraid. However, I would suggest that probably not many of the experts on the forum can speak Dutch. It may pay you to uninstall the version of Everest that you have, and install an English version from the link. You could then post another read out from the English version. All the best, I hope that someone can help.English version of Everest. Quote Link to comment Share on other sites More sharing options...
Robby1313 Posted March 7, 2005 Author Report Share Posted March 7, 2005 Thanks, I have changed it! Quote Link to comment Share on other sites More sharing options...
Boris Posted March 7, 2005 Report Share Posted March 7, 2005 Wheres the equivalent data to this for your Maxtor ?Disk Device Physical Info: Manufacturer IBM Hard Disk Family Deskstar 180GXP Family Code Name Vancouver 2 Form Factor 3.5" Formatted Capacity 123.5 GB Disks 2 Recording Surfaces 4 Physical Dimensions 146.0 x 101.6 x 25.4 mm Max. Weight 640 g Average Rotational Latency 4.17 ms Rotational Speed 7200 RPM Max. Internal Data Rate 699 Mbit/s Average Seek 8.5 ms Track-To-Track Seek 1.1 ms Full Seek 15 ms Interface Ultra-ATA/100 Buffer-to-Host Data Rate 100 MB/s Buffer Size 2 MB Quote Link to comment Share on other sites More sharing options...
Robby1313 Posted March 7, 2005 Author Report Share Posted March 7, 2005 I have found the problemThe BIOS setting for the IDE was not correctI changed it and now the SLAVE drive is okthanks for the help Quote Link to comment Share on other sites More sharing options...
andsome Posted March 8, 2005 Report Share Posted March 8, 2005 Glad that you are now sorted out. Stick around and join in the forum. Quote Link to comment Share on other sites More sharing options...
