strange problem....
Hi Everyone,
Im new in this forum.
My problem is this two days ago my windows xp started acting wierd without changing anything or installing anything in it.
The only problem that I might think about that it was a very hot day and I left the computer working all day long in a hot room.(I
oops....
anyway Ill continue here...
I got an amd 1000 athlon.
the problem is this.
When my hard disk reads my mouse get stuck momentarilly and it really mass up with my music cause it sound slower when the hard drive is reading or writing...
Last time it happened Ive installed the windows again...
Anyway can give me a clue or a suggestion to solve this problem.
thanks allot
Ron.
Hello, and welcome to the forum!
First thing to check if anything is out of the normal is if you have any malware on your system. Are you sure you are not infected with anything? If not, please download/install/run HijackThis, and post the result in this forum. Instructions for HijackThis can be found here.
Ah, scuzzman is obviously typing faster than me...
You might try some basic maintenance. Here's a little checklist:
-- Delete all temp files (c:\windows\temp\*.tmp, or on XP C:\Documents and Settings\username\Local Settings\Temp)
-- Delete temporary internet files (c:\windows\temporary internet files\*.*, or on XP C:\Documents and Settings\username\Local Settings\Temporary Internet Files)
-- If you use I.E., click on Tools, Internet Options, Delete Files, select "delete all off-line content", click OK
-- Click on Start, Programs, Accessories, Systems Tools, Disk Cleanup
-- Download AdAware, check for updates, run it and remove whatever it finds
-- Periodically empty the browser cache and the java plug-in cache
-- Download Diskeeper and defrag
-- Download, update and turn on SpywareBlaster and SpywareGuard (or your spyware removal tool of choice).
