littleruss21 Posted June 24, 2005 Report Share Posted June 24, 2005 ok i have a ibm server with win 2003 server on it with i believe sp1 on it (forgive me my boss has put me on figureing this out and i know very little about the hardware) so its a print server and he can print fine while on the server but from some clients he can't print (all client machines are the same...dell) and he just called and he was working on it and it got so bogged down and locked up he had to restart...any ideas?thanks in advance,littleruss21 Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted June 24, 2005 Report Share Posted June 24, 2005 You can find your version by clicking Start > Run > winverAs for the printer problem, have you set it up as a network printer, or a local printer which is shared? Quote Link to comment Share on other sites More sharing options...
littleruss21 Posted June 24, 2005 Author Report Share Posted June 24, 2005 i am unable to get near to the computer so i am doin this blind Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted June 24, 2005 Report Share Posted June 24, 2005 That's fine... But... have you set it up as a network printer, or a local printer which is shared?A Network Printer is one which has it's own built-in NIC or sometimes an add-on which provides a NIC port. A Shared Printer is one connected via Paralell or USB to a computer, and then shared from that computer.So you are "unable to get near the computer" does this mean you are working remotely?First thing to check is make sure the printer is on the same network as the computer trying to print (domain or workgroup) Quote Link to comment Share on other sites More sharing options...
littleruss21 Posted June 24, 2005 Author Report Share Posted June 24, 2005 ok they are network printers and the server (running windows server 2003) has all the printers set up on it and then theyare shared from there Quote Link to comment Share on other sites More sharing options...
scuzzman Posted June 26, 2005 Report Share Posted June 26, 2005 I've merged this and the post in the Windows Support forum. Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted June 27, 2005 Report Share Posted June 27, 2005 If you can't use Windows Networking to set up a printer, you can add a local TCP/IP printer. ("Local" means the settings are specified locally, not that the printer is nearby.)Open the add printer wizard, and make select local printer. uncheck automatically search. Create a new port (printer port). It will be a "Standard TCP/IP Port".put in the IP address and the port of the printer, and click next.after set-up you will need the drivers installed on each computer to run the printer. Quote Link to comment Share on other sites More sharing options...
littleruss21 Posted June 27, 2005 Author Report Share Posted June 27, 2005 all the printers are already set up its...the problem is when some clients print to a printer on the print server it takes a very long time...while others can print just fine Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted June 30, 2005 Report Share Posted June 30, 2005 Are the slow documents .pdf (Acrobat) files? Quote Link to comment Share on other sites More sharing options...
