Boris Posted August 28, 2005 Report Share Posted August 28, 2005 In the past couple of weeks I've had the message below pop up 3 times.System shutdownThis system is shutting down. Please save all ................... etc.This shutdown was initiated by NT AUTHORITY\SYSTEMThen a timed shutdown.The system processMessage'C:\WINDOWS\system32\services.exe' terminated unexpectedly with status code -1073741819. The system will now shut down and restartI googled and found that the code -1073741819 symptoms can be caused by the Sasser worm ???- so I turned off System Restore, - ran the Symantec FxSasser tool - which found nothing, - rebooted, - ran the tool again - still nothing.I'm running XP Pro (fully updated) plus AVG, SpySweeper, Trojan Hunter Guard - all up to date. Ran full AVG scan - nothing. Now trying Ewido.Any other bright ideas ? :unsure: Quote Link to comment Share on other sites More sharing options...
Boris Posted August 28, 2005 Author Report Share Posted August 28, 2005 I also found the following: When errors are large negative decimal numbers such as -1073741819, convert the error to hexadecimal then drop the required most significant digits. In this case, the correct decimal number for the Win32 error would be -1073741819 converted to 0xC0000005 which results in 5. An error code of 5 indicates the use of a third-party driver that is not compatible with the version of NDIS supplied with Windows XP Embedded. Also states that an error code of 5 means access denied. Quote Link to comment Share on other sites More sharing options...
-pops- Posted August 28, 2005 Report Share Posted August 28, 2005 Have a go with Stinger http://vil.nai.com/vil/stinger/ although a re-install from backup would be best. Quote Link to comment Share on other sites More sharing options...
Boris Posted August 28, 2005 Author Report Share Posted August 28, 2005 Ewido - nothing.Stinger found nothing either.+ I'd already restored from a back-up of 3 weeks ago (before this started).Mysterious ! Quote Link to comment Share on other sites More sharing options...
