cohrt Posted September 13, 2005 Report Share Posted September 13, 2005 Cannot connect Logitech Quickcam to USB via hub, but directly I can. What to do? Quote Link to comment Share on other sites More sharing options...
bvw Posted September 13, 2005 Report Share Posted September 13, 2005 It should connect OK with a powered hub...if the hub isn't powered you may have problems. Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted September 14, 2005 Report Share Posted September 14, 2005 I've had many problems with USB hubs. This is likely a power issue, and you may need to have the Camera directly plugged for it to work. I doubt there is anything else you can do short of purchasing a new hub that supports high power devices. Quote Link to comment Share on other sites More sharing options...
cohrt Posted September 15, 2005 Author Report Share Posted September 15, 2005 My webcam now after several tries functions directly connected to USB. My hub is powerassisted but does not function. Any idea in trying out another powerassisted hub? Quote Link to comment Share on other sites More sharing options...
-pops- Posted September 15, 2005 Report Share Posted September 15, 2005 I have never had any success with USB hubs - powered or unpowered. In my view they are the creation of the Devil. Many years ago they didn't work for me and I was asked to fit one the other day and again it didn't work reliably and this was a supposedly "good" Belkin one.Far better (and potentially cheaper) is to fit a USB PCI card. This does depend on you having room in your computer to accomodate this but it will end all these wil it/won't it work question you are getting with a hub. Quote Link to comment Share on other sites More sharing options...
