Blink_182_fan Posted September 21, 2005 Report Share Posted September 21, 2005 I currently use a Dlink Wireless Router and i share it with my Pc, My Brothers Laptop and my Family Pc.. My Brother recently bought a laptop and now basically is always downloading fron itunes etc.. And as i like to game .. I cant anymore.. It ends up that my Ping goes into the hundreds and i either get kicked for high Ping or leave because i cant move with the lag im getting..My Question to you's is.. Is there anyway i can Split my Internet Speed with My Brother so he isnt constanty using it all..? Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted September 21, 2005 Report Share Posted September 21, 2005 Probably not. Can you tell me the model of Dlink router you're using? I'll check the manual for it.What kind of software is he using for the file sharing? Maybe there is a way to throttle it back there? Quote Link to comment Share on other sites More sharing options...
scuzzman Posted October 3, 2005 Report Share Posted October 3, 2005 What you will need is a router with bandwidth throttling capabilities. Unfortunately, DLink doesn't make such a model, so you'll need to replace the router. Quote Link to comment Share on other sites More sharing options...
