A major problem!
redbullz
Sorry, it is another ill-informed computer question. On that note, please excuse my irrational computer knowledge, especially with Windows.
My family's Dell Dimension desktop now decides to play dysfunctional game with me, as my family don't have a bloody clue why it won't function. So now, it is up to me to repair it, but only with your help.
The Dell computer refuses to go any further than the setup menu which informs me a particular problem with a black background,
''Windows could not start because the following file is missing or corrupt - \windows\system32\config\system''
''You can attempt to repair this file by starting Windows setup using the original setup CD-ROM. Select 'r' at the first screen to start repair''
After many rapid continuous press of the button ''r'' with the Dell integrated Windows XP home setup disk loaded in the tray, it still repeats the problem
Help!
This is an indication of a corrupted registry.
Read about it here
I doubt if it will be of much help if, as you say, you don't have much computer knowledge.
From my point, I don't know just what Dell put on their recovery disk but perhaps someone else here may be able to give more advice on that.
Is there anyone local to you that you could ask to have a look at it for you?
Thanks, I have. I have also been suggested by some to investigate the link too. It does have me very bemuse. When I do inset the Dell tools CD for re-locating your hardrive because of corrupted data, it doesn't seem to response to it due I can't get any further than the setup menu - even the 'r' button for repair doesn't response either. Obviously a very flawed computer.
Would it be a safe bet to seek profession support? I have low patience with computers these days!.
