andsome Posted January 6, 2006 Author Report Share Posted January 6, 2006 Actually Molly 2 is little old me. It was the only way to prove that there is definitely something wrong on the board in my account. Under that name I was able to post links with NO BOTHER at all, using the little globe instead of copy and paste the URL.Edit: merged from "Let's see your website" - scuzzman Link to comment Share on other sites More sharing options...
andsome Posted January 6, 2006 Author Report Share Posted January 6, 2006 andsomeAfter many hours of experimentation, I have managed to recreate your problem.The cure I believe is very simple.The solution (I think) is .............................Go to My ControlsOptionsBoard Settingsand then in Posting Settings - Type of text editor to use when postingchange your drop-down box setting from (what I expect you have set as) Rich Text Editor to Standard EditorIt works for me ! :)Thanks for your trouble, I will try it now in this posting. GOOGLE. It looks like this is the anwser thanks Link to comment Share on other sites More sharing options...
andsome Posted January 6, 2006 Author Report Share Posted January 6, 2006 This all reminds me of the epitaph on Spike Milligans grave.I kept telling you that I was ill. Or words to that effect. Link to comment Share on other sites More sharing options...
