chelonian Posted February 9, 2006 Report Share Posted February 9, 2006 I can't seem to get any sound on my pc, any ideas what could be causing this? i've checked in Sound and Audio Device properties to ensure the speakers haven't been muted, and also checked everything has been plugged in correctly. The problem 'seemed' to arise after I removed my ipod usb lead from my pc :( Thanks for your help :) Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted February 9, 2006 Report Share Posted February 9, 2006 Have you tried System Restore?I am afraid there are not many options. If all volume controls are set (in windows, on the speaker and in the application) and nothing is muted, then perhaps a system restore is the way to go.You could also try re-installing your audio drivers.Have you removed your iPod using the "Safely remove hardware" button? Quote Link to comment Share on other sites More sharing options...
chelonian Posted February 9, 2006 Author Report Share Posted February 9, 2006 I'm fairly sure I used the 'Safely remove Hardware' button when I removed the ipod, but its possible in my hastiness i didn't.How would I go about completing a system restore and re-installing audio drivers as you have suggested?Thanks :) Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted February 9, 2006 Report Share Posted February 9, 2006 System restore can be done by going to:Start > All Programs > Accessories > System Tools > System Restore.Choose a date before you noticed the sound was gone.As for drivers, it depends on what Sound Card you have. Do you know what Make and Model your sound card is? Quote Link to comment Share on other sites More sharing options...
chelonian Posted February 9, 2006 Author Report Share Posted February 9, 2006 I have completed the system restore but, still no luck :(I'm not sure what sound card I have :unsure: How would I find that information?thanks again Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted February 10, 2006 Report Share Posted February 10, 2006 Right-click on My Computer -> Properties -> tab Hardware -> Device manager. Scroll down to Sound, video and game controllers, and click on the [+] on the left. Somewhere in there you have your sound card.Right-click on the sound card -> Properties -> tab Driver. You should be able to see the driver version there.If you give us all these information (sound card and driver version), someone here can tell you where to find the latest driver.One more option: does your computer have a hardware volume control? If so, check if it is turned on. Can you tell us your computer model; maybe someone can tell you where the possible HW volume control might be. Quote Link to comment Share on other sites More sharing options...
chelonian Posted February 10, 2006 Author Report Share Posted February 10, 2006 I'm not the most technical i'm afraid,but, I have tried to get the information you have mentioned.There doesnt seem to be an option for 'sound card' exactly, but I think this is the information you need (?)C-Media WDM Audio DeviceDriver date: 15/12/2005Driver Provider: C-Media IncDriver Version: 5.12.1.50Provider: C-Media CorporationComputer:AMD Athlon XP2400+ :unsure: I'm missing listening to my music sooooo much so any advice would be helpful and appreciated!!! ;) Kind Regards :) Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted February 11, 2006 Report Share Posted February 11, 2006 C-Media DriversBut you will need to know which card...SIW is a good program for finding such information. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted February 11, 2006 Report Share Posted February 11, 2006 That driver seems pretty much up-to-date (15/12/2005). Did you install it recently, or was it installed by WindowsUpdate?Also, did you check if you have a hardware volume control? Quote Link to comment Share on other sites More sharing options...
-pops- Posted February 11, 2006 Report Share Posted February 11, 2006 Is there a "mute" button on the keyboard that may have accidentally been pressed? Quote Link to comment Share on other sites More sharing options...
chelonian Posted February 11, 2006 Author Report Share Posted February 11, 2006 Problem Sorted!!!!!!!! :)Yay!!!!!!!!By uninstalling and re-installing C-Media!!!!!Thanks for all your kind help and suggestions guysVery Very much appreciated:) Quote Link to comment Share on other sites More sharing options...
