2 Systems
Try Me
There are a few steps involved.
First, edit your boot.ini file so you do not have a choice of Windows XP Professional.
The boot.ini file can be loaded by going to: start > run > C:\boot.ini. Delete the line that say's Windows XP Professional, and make sure, under the [Default] header, the Windows XP Home edition is set.
Then, you will have to delete the windows folder. This can also be found in the boot.ini file, as the line associated with Windows XP Pro will be labeled as Windows or Windows(2) or something to that effect. You will need to delete this folder.
Most i Rename The Boot.ini ? the boot.ini file is a note .. so can i rename the file its now
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(2)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Home Edition (TuneUp Backup) (bootscreen)" /noexecute=optin /fastdetect /TUTag=JIPL8T /Kernel=TUKernel.exe
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Home Edition (TuneUp Backup) (bootscreen) (TuneUp Backup)" /noexecute=optin /fastdetect /TUTag=JIPL8T-BAK /KERNEL=kernel1.exe
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect /TUTag=W8ZAQF
Help me Thnx
I hope this helps, this is for XP pro, so if you just want home it will give you an idea of what to delete and how to do it.
computer.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect
Save a Backup Copy of Boot.ini
1. Right-click My Computer, and then click Properties.
-or-
Click Start, click Run, type sysdm.cpl, and then click OK.
2. On the Advanced tab, click Settings under Startup and Recovery.
3. Under System Startup, click Edit. This opens the file in Notepad ready for editing.
4. In Notepad, click File on the Menu bar, and then click Save As.
5. Right click in an empty area of the Save As dialThis is a sample of a default Boot.ini file from a Windows XP Professionalog box, point to New in the Context menu, and then click Folder.
6. Type a name for the new folder, for example temp, and then press the ENTER key to create the folder named temp.
7. Double-click the new folder named temp, and then click the Save button to save a backup copy of the Boot.ini file.
Edit the Boot.ini File
To view and edit the Boot.ini file:
-or-
If you should delete the wrong line, reboot your computer and keep tapping the F8 key to boot into safe mode then access your saved Boot INI file and restore it.
computer.
[boot loader]
timeout=30
[operating systems]
-or-
-or-
so if i delete this line(multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect) of Professional i have deleted everthing of Professional ?
Please reply thnx ;)
This may be of help :-
You can also use the Dos Command BOOTCFG to edit the boot.ini file.
use the query switch to show the file controls and ID's
you can then change the Boot order or remove one (or more) of the systems to boot.
For Help type bootcfg /?
Ie: ID 1 Windows XP Home Note This is NOT the full inf display of the bootcfg /query
ID 2 Windows XP Pro
to make Boot on XP home only bootcfg /delete ID2
to make Boot on XP Pro only bootcfg /delete ID1
Make a COPY of the original Boot.ini first just in case.
Looking at your posting, you need to delete all these lines and leave the last line intact.
Make sure you do a back up to the desktop before trying this so it can be restored in safe mode if it goes wrong.
my boot.ini is now :
[boot loader]
timeout=0
[operating systems]
is that corect ?
