Peano Posted February 11, 2006 Report Share Posted February 11, 2006 After reloading Win2K, the device manager shows a yellow ? for "other devices" and under that "PCI device" -- it says the device has no driver. I tried searching the original driver CD that came from Dell, but nothing there.Any idea what this "device" is and where I might find a driver? Many thanks. Quote Link to comment Share on other sites More sharing options...
r4may Posted February 11, 2006 Report Share Posted February 11, 2006 Try Belarc Adviser it may show the information you require:-Free Download from http://www.belarc.com/free_download.html Quote Link to comment Share on other sites More sharing options...
trackrat Posted February 11, 2006 Report Share Posted February 11, 2006 Try Everest Home, when it is installed run the program and click on Devices in the left hand pane then click on PCI devices and it will list all of them on your computer. it can be downloaded from here.http://www.majorgeeks.com/download4181.html Quote Link to comment Share on other sites More sharing options...
andsome Posted February 12, 2006 Report Share Posted February 12, 2006 Try Everest Home, when it is installed run the program and click on Devices in the left hand pane then click on PCI devices and it will list all of them on your computer. it can be downloaded from here.http://www.majorgeeks.com/download4181.htmlThanks, I'm glad you posted that. This version is more up to date than mine, so I have downloaded it before it disappears altogether. Quote Link to comment Share on other sites More sharing options...
