WinHelpPlz3 Posted April 6, 2006 Report Share Posted April 6, 2006 I have my original hard drive with windows xp professional and i have an extra slave hard drive. They are both in my computer. Windows XP gives me this message every few days when I boot up:"One of your disks needs to be checked for consistency ..."It used to dual boot and i went to boot.ini and set the timer for 0 sec so it would not pop upI just want to have my operating system on my master hd.How do I delete my whole operating system from my slave drive?Can I do it by deleting it while I'm on the computer, or do I have to do a DOS Prompt or something?Any help would be great.Thanks Quote Link to comment Share on other sites More sharing options...
Jookia Posted April 6, 2006 Report Share Posted April 6, 2006 Format slave and re install mbr with no slave in the computer then put slave back in Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted April 7, 2006 Report Share Posted April 7, 2006 As Jookia says, you will need to format your slave, and install a new MBR.Make sure you have everything off your slave, and format it. This can be done in Windows.Then, type msconfig into the run command and go to the boot.ini section. Click 'Check All Boot Paths', and now since the slave has been formatted, it should clear the line associated with the slave. You should not need to disconnect your slave drive. Quote Link to comment Share on other sites More sharing options...
WinHelpPlz3 Posted April 7, 2006 Author Report Share Posted April 7, 2006 Thank you for explaining it moreI did not really want to take out everything again Quote Link to comment Share on other sites More sharing options...
andsome Posted April 7, 2006 Report Share Posted April 7, 2006 Glad your problem has been sorted. Stick around now that you have found us. Quote Link to comment Share on other sites More sharing options...
