Problem with display settings
feelix
http://img168.imageshack.us/img168/669/bghelp3nh.jpg
okay, you know how under all icons on your desktop there is writting(usually with the program name). Well look at my image, you see how behind the writting there is the grey background? and it looks kinda sloppy. Is there anyway I can remove that small grey bg from behind the text? I used to have a clear background and it looked really clean and nice. How can I restore the clear transparent background behind the writting.
please help!
thanks
