pudgie Posted May 2, 2006 Report Share Posted May 2, 2006 my @ is my ". and my taskbar and part of the bottom of the screen disappear disappears when i change my resolution to 1280 x 1024. any help ?? Quote Link to comment Share on other sites More sharing options...
trackrat Posted May 2, 2006 Report Share Posted May 2, 2006 Where @ is " your keyboard is set for US,To change it if you are using XP, click on start, Control panel, Date/time/language & regional options, then Regional options (This is in Category view)Then Regional & language options and you can change the default setting from there.(if you are using the classic view) Just clck on the Regional & language icon which will bring up the box you require.I cannot help with your other problem. Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted May 2, 2006 Report Share Posted May 2, 2006 If your taskbar disappears, you will need to adjust your monitor's size settings using the control on the monitor itself. Quote Link to comment Share on other sites More sharing options...
pudgie Posted May 4, 2006 Author Report Share Posted May 4, 2006 sorry but i have a laptop and cant do the above. thankyou to the other guy Quote Link to comment Share on other sites More sharing options...
korgg Posted May 4, 2006 Report Share Posted May 4, 2006 What laptop do you have ? Maybe we can get a hint from this...Also, does your laptop monitor supports that resolution ? See in Display settings if there are some controls that allow you to modify the screen... Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted May 5, 2006 Report Share Posted May 5, 2006 Also, what version of Windows do you have? In Win 9x/ME it is quite different to change the keyboard drivers than NT/2K/XP. Quote Link to comment Share on other sites More sharing options...
Mr. H Posted May 22, 2006 Report Share Posted May 22, 2006 my @ is my ". and my taskbar and part of the bottom of the screen disappear disappears when i change my resolution to 1280 x 1024. any help ??Hi Pudgie. It sounds very much like you are trying to use a screen resolution that is greater than the native/highest resolution of your display. When you set the display to 1280 x 1024, if you move the mouse down to the bottom of the display, does the picture move to reveal the taskbar? If so, your monitor doesn't support 1280 x 1024 (or at least, Windows doesn't think it does). Quote Link to comment Share on other sites More sharing options...
