Connect USB Hard Drive to the Network?
I would never use a wireless link for anything as important as a backup. Any fluctuation in the data transfer will ruin the writing to disk and thus the backup.
Reliable as you may think wireless connections may be, a hard wired setup is really the only reliable way to go in important data transfer.
Regarding using an Ethernet connection, why? You have the USB facility already there. Introducing Ethernet (and the necessary conversion to USB) is an unnecessary complication - you are making a complex job out of a simple one.
I'm still of the opinion that you would introduce unnecessary complexity into your setup.
I have three machines linked by a wireless network but for my monthly backups to an external hard drive (with three partitions) I plug in via USB into each machine as required. I make a full system backup of my main machine once a week to a dedicated internal drive.
With Ethernet connections, I cannot see any advantage at all. You would still need to separately plug each machine into the drive to carry out the backup so, why not just use the facility already there i.e. USB.
I think you require/want NAS?
Network Attached Storaged?
Where it would plug into the router and then be accesed via any PC?
There is a product that can connect your USB HDD to the router via Ethernet but I can't find it...
EDIT: Network Storage Link for USB 2.0 Disk Drives Easily Add Storage Space to Your Network :rolleyes:
