Angel Gonzalez Posted June 15, 2006 Report Share Posted June 15, 2006 I am practicing modding with my computer after my retirement as consequence changed many motherboards, graphic cards and HD which I damaged overclocking or learning the last four years..lately, may 24, I validated my windows xp profesional by maybe twenty times by phone and worked fine; however two days ago this error message oubreaks in my screen "your program is not original" and the messenger didnt works also the validation was lossed.I bougth this xp in the best store in San Jose, COMPUAMERSA, for years ago and I have my invoice as consequense called them aboutb the software error as not original but they explain is that xp had limitation in the number of validation to be do it.It is true and I must to buy another copy or the problem could be solved.çI appreciate your help. Angel Gonzalez San Jose Costa Rica Quote Link to comment Share on other sites More sharing options...
benb Posted June 16, 2006 Report Share Posted June 16, 2006 Have you tried calling Microsoft and explaining the situation to them? I have heard good things about Microsoft and XP versions. Quote Link to comment Share on other sites More sharing options...
-pops- Posted June 16, 2006 Report Share Posted June 16, 2006 In situations like yours it is necessary to contact Microsoft by telephone and explain the situation to them. If your explanation is reasonable and within the Windows EULA you will be given a new product key. If your explanation is not acceptable then, as you say, you must buy another copy of Windows.Microsoft are very helpful when you contact them and this is the only way to remedy the situation you are in. :) Quote Link to comment Share on other sites More sharing options...
Angel Gonzalez Posted June 16, 2006 Author Report Share Posted June 16, 2006 In situations like yours it is necessary to contact Microsoft by telephone and explain the situation to them. If your explanation is reasonable and within the Windows EULA you will be given a new product key. If your explanation is not acceptable then, as you say, you must buy another copy of Windows.Microsoft are very helpful when you contact them and this is the only way to remedy the situation you are in. :) Quote Link to comment Share on other sites More sharing options...
Angel Gonzalez Posted June 16, 2006 Author Report Share Posted June 16, 2006 I appreciate your answers which looks logic. My past experience with microsoft were very goods in regards support. I trying to know if exist any fixed rules in regards number of reactivation as they said in the store. thanks very much newly. Angel Quote Link to comment Share on other sites More sharing options...
-pops- Posted June 16, 2006 Report Share Posted June 16, 2006 There are restrictions on the number of automatic online activations you can do - depending also on the changes to hardware and software that have been made. By activating by telephone you can explain to Microsoft what has been done and why you need to activate again - this is something a computer activation cannot understand - that just follows the rules. Quote Link to comment Share on other sites More sharing options...
Angel Gonzalez Posted June 16, 2006 Author Report Share Posted June 16, 2006 In merit of microsoft they tried to help to me through phone and check that YES the software is genuine in spite the problem cannot be solved yet expending more one hour by phone making test on my pc through internet and promising new contact next week to take time to research a solution my impresion is that the service is gentle and excelent.I am very happy with their service and ready to buy vista as soon is in the market!thanks you for your help Angel Quote Link to comment Share on other sites More sharing options...
-pops- Posted June 16, 2006 Report Share Posted June 16, 2006 Stick around and let us know how you get on with Microsoft. :) Quote Link to comment Share on other sites More sharing options...
Angel Gonzalez Posted June 19, 2006 Author Report Share Posted June 19, 2006 I am comeback to explain that in two long sesion by phone from argentina, I believe, Alejandro Ameal from technical departament solved my xp problem and also provided me with usefull information about how optime xp and Vista new OS.I take opportunity to give my sincere thanks to all you that recomend contact directly microsoft because WORKS!Thanks very muchAngel Gonzalez Costa Rica Quote Link to comment Share on other sites More sharing options...
