raitzin Posted June 25, 2006 Report Share Posted June 25, 2006 I just bought a monitor that requires a 1680x1050 @ 60Hz for optimum performance. Windows settings don't go that high. Any suggestions on how to get there? My graphics card is NVIDIA GeForce FX 5200.Thanks a lot! I appreciate the help! Quote Link to comment Share on other sites More sharing options...
andsome Posted June 25, 2006 Report Share Posted June 25, 2006 I just bought a monitor that requires a 1680x1050 @ 60Hz for optimum performance. Windows settings don't go that high. Any suggestions on how to get there? My graphics card is NVIDIA GeForce FX 5200.Thanks a lot! I appreciate the help!Even though my monitor runs perfectly well without drivers, it came with a CD containing drivers. With these drivers installed I can right click on the desktop and go to Properties/Settings/Advanced/Monitor, and change the setting there. It is best to click on the box that says "Hide settings that this monitor cannot display". Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted June 25, 2006 Report Share Posted June 25, 2006 Also, if your video card does not support that resolution, it will not allow you to go that high.From what you've given, the FX5200 goes to 2048 x 1536, but there are several different models.You might want to install the latest drivers from http://www.nvidia.com as well as andosme suggests, your monitor drivers. Quote Link to comment Share on other sites More sharing options...
