Guest ellas Posted June 23, 2003 Report Share Posted June 23, 2003 ok just installed a usb2 card and a case fan that plugs into a 3 pin in the mobo now my computer will not shutdown,any ideas nothing reported in windows everything is running fine how am I going to shut this down to sort it out my hunch is the case fan. Quote Link to comment Share on other sites More sharing options...
Guest LB Posted June 23, 2003 Report Share Posted June 23, 2003 have you checked the event log in Control Panel > Administrative tools > event viewer? Any errors will be logged in there and could go some way to explain the problem. Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted June 23, 2003 Report Share Posted June 23, 2003 yes and not a single error. Quote Link to comment Share on other sites More sharing options...
mark2 Posted June 23, 2003 Report Share Posted June 23, 2003 Is it windows not shutting down or the comp not switching off? Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted June 23, 2003 Report Share Posted June 23, 2003 the computer itself its just started doing this. Quote Link to comment Share on other sites More sharing options...
Guest Nellie2 Posted June 23, 2003 Report Share Posted June 23, 2003 well you can get it to turn off by holding your start button in for about 4 seconds. But that doesn't actually solve your problem though Quote Link to comment Share on other sites More sharing options...
mark2 Posted June 23, 2003 Report Share Posted June 23, 2003 I would go for pulling the plug to switch off initially unplug the case fan reboot then see if it all shuts down normally ? Quote Link to comment Share on other sites More sharing options...
mark2 Posted June 23, 2003 Report Share Posted June 23, 2003 Also look in device mangler >computer > ACPI, check that the driver is working properly . Quote Link to comment Share on other sites More sharing options...
mark2 Posted June 23, 2003 Report Share Posted June 23, 2003 http://www.pcadvisor.co.uk/index.cfm?go=di...95353&forumid=1someone else with a similar problem Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted June 24, 2003 Report Share Posted June 24, 2003 ok sorry I missed a important other fact for you I was also using a new monitor ,guess what this is what was causing it,traced it to the 15 pin video lead except its not theres a pin missing its only got 14pins so a replacement is needed :angry:p.s nellies is the way to go for switching off,I would only pull the plug as a last resort. Quote Link to comment Share on other sites More sharing options...
Guest Nellie2 Posted June 24, 2003 Report Share Posted June 24, 2003 ok sorry I missed a important other fact for youDuh!!!! :blink: :rolleyes: :D Quote Link to comment Share on other sites More sharing options...
