radio Posted June 26, 2003 Report Share Posted June 26, 2003 Everytime I delete multiple files from explorer or the desktop, I get an error message.1. I get the "confirm multiple delete" message.2. I click "yes" then I get this error message:"Explorer cause an invalid page fault in module <unknown> at 0000.00000000"WHAT IS THAT? That never happened before.Another weird thing, it ONLY happens if I delete 2 or more files together (i.e., if I empty my temp folder). It's really irritating cuz I have to delete files one at a time.HELP! :( Quote Link to comment Share on other sites More sharing options...
mark2 Posted June 26, 2003 Report Share Posted June 26, 2003 Which OS ?Have you defragged and run disc clean up recently ?How many other progs are running at the time ?Have you tried deleting them in safe mode? Quote Link to comment Share on other sites More sharing options...
radio Posted June 26, 2003 Author Report Share Posted June 26, 2003 Running Windows 98 SE.I ran scandisk and defragged - That's the first thing I did.Only active programs I have running in background are Norton, Nvidia desktop manager, and EasyCD - pretty much the same programs I had running before all this started.I recently installed windows media player 9 and the mp9 update.Other than that, didn't really do anything else with my system.It's a pretty weird problem. Could it be a problem with the registry? Quote Link to comment Share on other sites More sharing options...
Guest moon Posted June 26, 2003 Report Share Posted June 26, 2003 Hi radio :) Good registry analysis, if that's the prob. jv16 free download.http://www.jv16.org/ Quote Link to comment Share on other sites More sharing options...
Guest VoG™ Posted June 26, 2003 Report Share Posted June 26, 2003 If it is a problem with the registry then you could try Start, Run, enterSCANREG /FIXand click OK. Quote Link to comment Share on other sites More sharing options...
radio Posted June 28, 2003 Author Report Share Posted June 28, 2003 I tried scanreg - it reported no problems.I'm not really sure what's causing it. It's pretty weird - AND very annoying. Quote Link to comment Share on other sites More sharing options...
