branbran31 Posted November 17, 2006 Report Share Posted November 17, 2006 Hello, first my volume icon disappeared from the bottom right toolbar, and I've tried everything under the sun to get it back, but nothing worked.Also, my volume doesn't work with some websites, and it does with others. One site it doesnt work with is the YOUTUBE site and any other site that plays those type of applications, like movie trailers and such. I use the driver that came with the computer, and I run XP. It had been working properly before, it recently stopped working with some sites about a week ago. Thank you for your helpB Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted November 17, 2006 Report Share Posted November 17, 2006 Hello, and welcome to the Windows Forum!You write that you "tried everything", but of course we don't know what that is. Did you, for example, check 'Place volume icon in the taskbar' in the Sounds applet in Control Panel? Quote Link to comment Share on other sites More sharing options...
-pops- Posted November 17, 2006 Report Share Posted November 17, 2006 I had problems with the sound on one of my machines the other day. The volume was very low and nothing I did would make it any louder.I did a cold re-boot (including turning the power to the computer off). It was OK after that.Have you tried a cold re-boot? Not saying it will work but, it may do and you don't lose much by trying. Quote Link to comment Share on other sites More sharing options...
D4\/!d Posted November 17, 2006 Report Share Posted November 17, 2006 Or, although your volume control is turned up full (100%), it maybe that *the player* you use also has a volume control and that has somehow got knocked and turned down/off. I know. I've the same thing myself Quote Link to comment Share on other sites More sharing options...
branbran31 Posted November 17, 2006 Author Report Share Posted November 17, 2006 Hello, and welcome to the Windows Forum!You write that you "tried everything", but of course we don't know what that is. Did you, for example, check 'Place volume icon in the taskbar' in the Sounds applet in Control Panel?Thank you, Yeah, I went into the properties of the tool bar, I went into sound and audio options in control panal. I checked all my levels, although, my cd player and other media applications work. It's just certain players on websites do not.I went through internet options, I even checked on my sound card, but like I said, its hasn't completely stopped. I went through some steps that took me through the Start>Run>config stuff. I went to the Register Key and took steps through that HCKEY file. Can't think of the other things that I've tried. Hope this helps....And yes I did a cold reboot, shut it all down and let it set for like 30 minutes, then rebooted everything....nothing..Thank you very much, B Quote Link to comment Share on other sites More sharing options...
-pops- Posted November 17, 2006 Report Share Posted November 17, 2006 Hmmm....Assuming you're on WXP (or ME), try a System Restore to a time before this happened. Quote Link to comment Share on other sites More sharing options...
branbran31 Posted November 17, 2006 Author Report Share Posted November 17, 2006 Hmmm....Assuming you're on WXP (or ME), try a System Restore to a time before this happened.I'm a little ignorant on the whole System Restore subject. Can you tell me how to do it? I thought I had removed something I shouldn't have from the add/remove page. Not sure, but the sound wouldn't work at all if I had done that, right?Thanks for your help, B Quote Link to comment Share on other sites More sharing options...
-pops- Posted November 17, 2006 Report Share Posted November 17, 2006 Click on Start -> Help & Support -> System Restore then follow the instructions. Quote Link to comment Share on other sites More sharing options...
branbran31 Posted November 17, 2006 Author Report Share Posted November 17, 2006 Click on Start -> Help & Support -> System Restore then follow the instructions.AWESOME!! The system restore worked......THANK YOU POPS!!!! :D :D :D Quote Link to comment Share on other sites More sharing options...
-pops- Posted November 17, 2006 Report Share Posted November 17, 2006 - - - and another satisfied customer :)Stick around! Quote Link to comment Share on other sites More sharing options...
