Rupert Posted November 19, 2006 Report Share Posted November 19, 2006 Hi,I recently installed some Casio Camera software to download some pics for a friend.Now I have finished tried Control Panel > Add/Remove Programs etc. but I try to remove it, get a message saying that a particular file .......Plauto.exe is in use so close it down first.As far as I can tell no programs are running I am just at my Desktop.Can someone advise please the best way to remove this software please?There is not a separate Uninstall routine with the program.Thanks. Quote Link to comment Share on other sites More sharing options...
Boris Posted November 19, 2006 Report Share Posted November 19, 2006 Have you booted into Safe Mode and tried to uninstall it from there ? Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted November 20, 2006 Report Share Posted November 20, 2006 It's possibly a startup program that is always running. Check with the Task Manger, end the process, and try the uninstall again. Or, as Boris suggested, try uninstalling in safe mode. Quote Link to comment Share on other sites More sharing options...
andsome Posted November 20, 2006 Report Share Posted November 20, 2006 If it has an icon in the system tray, you could try right clicking it and selecting EXIT. Quote Link to comment Share on other sites More sharing options...
Rupert Posted November 20, 2006 Author Report Share Posted November 20, 2006 Thanx Guys,Managed in Safe Mode. Quote Link to comment Share on other sites More sharing options...
