D4\/!d Posted November 21, 2006 Report Share Posted November 21, 2006 If you use a USB drive, you might find this handy:http://portableapps.com/suite Three versions to choose from: * Standard: 89.5MB (download), ~260MB (unzipped and installed) * Lite: 30.4MB (download), ~105MB (installed) - Uses the smaller AbiWord instead of the whole OpenOffice suite * Base: 0.7MB (download), 1MB (installed) - Choose the Apps you want and install them separatelyNot only does it install portable apps on your USB drive, it has a program-launcher and backup utility.Not tried it myself yet but it looks good :) Quote Link to comment Share on other sites More sharing options...
Thos Posted November 21, 2006 Report Share Posted November 21, 2006 Thank you.It looks interesting. I was wondering whether to download the Thunderbird portable app to a portable pen drive. I read the "walk through set-up" procedure but found it more than difficult to understand. What to enter in the outgoing and incoming server boxes was a mystery to me.Thos. Quote Link to comment Share on other sites More sharing options...
D4\/!d Posted November 21, 2006 Author Report Share Posted November 21, 2006 Yeah it always baffles me too. It's things such as the following that seem to work for me. Incoming mail (pop3): pop3.blueyonder.co.ukOutgoing mail: smtp.blueyonder.co.ukI am on blueyonder and these are my outlook express settings, I guess if you try something similar using your isp, it might work for you. Let's hope so :) Quote Link to comment Share on other sites More sharing options...
Thos Posted November 24, 2006 Report Share Posted November 24, 2006 Thanks. 1st hiccup was that when I opted for the base set-up, I downloaded and installed the suite. But I couldn't install the Thunderbird app. Then I noticed that there was a bug preventing this and a patch was available. Dowloading that cured it.2nd hiccup was the settings. I did as you suggested and the account was set up.3rd hiccup was the password. I tried all sorts until my brain kicked in and I remembered the password when I originally set up the Sky OE account.Like magic, it all opened up and now on a pen drive about an inch long and half an inch wide with a capacity of only 125mb, I am able to plug in when on my travels and send and receive e-mails.Thanks, D4\/!dThos. Quote Link to comment Share on other sites More sharing options...
