deuces wild Posted December 9, 2006 Report Share Posted December 9, 2006 I have just hooked up my new 19" LCD monitor. It came with 2 cable connections to the desktop, including a DVI cable which was listed as optional.The instruction manual did not explain the benefits of using this cable.Is there an advantage? If so, do I still connect both cables to the desktop or just the DVI?TIA! Quote Link to comment Share on other sites More sharing options...
AlanHo Posted December 9, 2006 Report Share Posted December 9, 2006 You should get a better display with the DVI (digital) rather than the analogue connection because the monitor does not have to convert the analogue signal to its native digital.You only need the one cable connected. Quote Link to comment Share on other sites More sharing options...
deuces wild Posted December 9, 2006 Author Report Share Posted December 9, 2006 Thanks Alan! Quote Link to comment Share on other sites More sharing options...
