Guest Windows Forum Guest Posted January 9, 2003 Report Share Posted January 9, 2003 So then, got AVG running along with Sygate's firewall but I recently have noticed harddrive activity at funny times (and it can't be either space or memory hunting - there's loads spare). Also recently I was looking for a decent file shredder and when exiting one of the sites the damn thing threw me a snapshot of my root drive to "prove" that I was "unprotected" which not only doesn't convince me to trust the site but also leaves me doubting my firewall.Any idea if the hd activity could be a trojan or similar? Link to comment Share on other sites More sharing options...
mark2 Posted January 9, 2003 Report Share Posted January 9, 2003 Possibly something on your PC looking for an update, which o/s are you using, do you have M$ office on there. There are a nunber of things that could account for this HD activity. Link to comment Share on other sites More sharing options...
Guest Windows Forum Guest Posted January 9, 2003 Report Share Posted January 9, 2003 OS is XP (home not pro). I do have other m$ stuff on the system in the way of hardware but not software. (that's to say the mouse and the joystick)The thing is I don't have to be online for the xtra activity to kick in. It's just a bit weird and worrying. Link to comment Share on other sites More sharing options...
Guest ellas Posted January 9, 2003 Report Share Posted January 9, 2003 have a look at the GAV board,I believe mark2 runs this as a added a/v (not on permanent protection) and its also a trojan scanner,sure mark2 will give you more info,got great results when one of our members had trojans installed and we are also in direct contact with the GAV creator if there are any problems,if fact me and craig are moderators at there forum. Link to comment Share on other sites More sharing options...
mark2 Posted January 9, 2003 Report Share Posted January 9, 2003 You could then have disc indexing enabled this would account for the HD activity you are reporting, have a look here http://www.blkviper.com/WinXP/servicecfg.htm for hints on disabling it and other unneeded services. Once they are disabled see whether the prob is still there Link to comment Share on other sites More sharing options...
mark2 Posted January 9, 2003 Report Share Posted January 9, 2003 As a backup on demand scanner GAV is the puppies privates for a FREE a/v and trojan scanner Link to comment Share on other sites More sharing options...
Guest Windows Forum Guest Posted January 9, 2003 Report Share Posted January 9, 2003 Cheers for that.I shall have a look at the threads / sites in question. Link to comment Share on other sites More sharing options...
mark2 Posted January 9, 2003 Report Share Posted January 9, 2003 Post back if you feel there is still a problem or not! even :P Link to comment Share on other sites More sharing options...
mark2 Posted January 9, 2003 Report Share Posted January 9, 2003 Ps the popup showing the contents of your drive, evidence eliminator perhaps 'Scareware' take a look here http://www.informationweek.com/841/langa.htm Link to comment Share on other sites More sharing options...
Guest Dan Posted January 9, 2003 Report Share Posted January 9, 2003 That looks right to me. It certainly alarmed me though it didn't make me go "Darned I must need their kit" it made me disconnect asap. So perhaps not such a great gimmick as they think.It wasnt on EE's site but a similar kind of proggy.blkviper.com is going to take some trawling through though so I may be sometime. Link to comment Share on other sites More sharing options...
Guest Dan Posted January 9, 2003 Report Share Posted January 9, 2003 Sorry - I'm a changed man . Link to comment Share on other sites More sharing options...
mark2 Posted January 10, 2003 Report Share Posted January 10, 2003 There we were thinking it was the FE hiding in anonymity :D :D Link to comment Share on other sites More sharing options...
Snec Posted January 10, 2003 Report Share Posted January 10, 2003 All I can tell you is AVG did not stop me getting Klez. But that is the only time I've had a mishap with it in over 18 mths of use and when I sent AVG on the trail -- it did get it.It was my own fault too really. I'd got a grandson stopping with me at the time and I opened (an admittedly dodgy looking) email because I thought it was in reply to something he had told me he was waiting for. I then did an AVG scan straight away and it got it then. Since then I do a regular scan (most days). Link to comment Share on other sites More sharing options...
Guest Dan Posted January 14, 2003 Report Share Posted January 14, 2003 Will Gav run ok on demand alongside my current virus killer AVG? Link to comment Share on other sites More sharing options...
mark2 Posted January 14, 2003 Report Share Posted January 14, 2003 Runs ok on demand as a double check, I often forget to disable AVG an have had no conflicts.GAV's scanner has been updated recently and is quicker now, get the updates as there have been more trojans added too Link to comment Share on other sites More sharing options...
