To search for mails for more than 1 specific words
Huamin
I have Lookout for Outlook installed to search my mail. You can search for multiple words like
"two words"
-or-
two + words
plus many other combinations. Unfortunately I cannot find the download location any more (Lookoutsoft has been acquired by Microsoft, and Lookout has been incorporated into Windows Desktop Search). However, I still have the installer, and I can send it to you if interested.
Of course if you have the full Windows Desktop Search installed, you can search with the same methods. Same for Google Desktop Search or Copernic.
As I am the regular user of "advance search" of MS Outlook, I don't agree with you Pat. If you use some unique combinations, I don't think it takes long to get the required results. And yes it also depends on your machine speed and volume of the mails. :)
Any way the alternate option suggested by you also required .net if you are using the latest 2003 version of Outlook.
It is even more difficult if you have more than one mail store, e.g. a Personal Folders File with subject folders, an archive PST file, and current messages stored on an Exchange Server. With Outlook search you have to search each store separately, and if the Exchange Server is on a remote location, it can take a very long time to return some results. Lookout just takes a few seconds to return results from 10 years of stored mail.
But back to the Advanced Find in Outlook. I haven't found any useful info in Help. How would you for instance specify
search for keyword1 AND keyword2
search for keyword1 OR keyword2
