hardware or oftware problem?
bembaman
I had the 'blue screen of death' occur recently on several occasions, different messages.I backed everything up and got a new hard drive. However, I am trying to install XP SP2 and have encountered a problem. The set up goes fine and I get as far as installng the installation files to the installation folders (ie the bit where the yellow installation bar reaches 100%) The computer then restarts, which I think is normal, but then when it re-starts it just goes back to booting off the CD as a completely fresh installation and reaches the same point again and restarts etc. I am going round in circles.
Anyone got the answer for this, and is my initial assumption that it is hardware related wrong?
Obviously something wrong. When I reinstall Windows, I am always told that I need to restart the computer at the very end of the installation. At this point I remove the CD and tell the machine to reboot, and it does so from the hard drive.
