Drive Encyption and Paging File/Tempfiles
I am trialing drive encryption (TrueCrypt) and have created an encrypted D drive. I set my paging file to exist on the D drive so it is also encrypted and therefore safe and done the same with the temp directories.
The problem is the screen goes all funny at boot time (splits into 4 sqiggly screens) and then comes up. It was unable to create the pagefile as there is not yet a d drive. You have to use truecrypt to make the d drive by putting in the password, which makes sense since that's what keeps the data safe.
The temp directories are used after the d drive becomes available but the pagefile.sys is not created or used that I can tell. This is a problem because either it means I have to keep the pagefile on the unencrypted C drive which is a security risk or I have to do without a pagefile entirely.
Has anybody come across this issue and got any ideas for dealing with it? Perhaps you use some other drive encryption software which you think is better?
I can't answer your query but I would ask if you have a good reason for encrypting your files?
I was caught out once by an encryption system which forgot its own password. No, it wasn't me that forgot it, the software did. The suppliers of the software didn't deny that their product had done this so I can only assume that it has happened to others.
Somewhere there is still a hard drive containing my encrypted files, never to be seen again. Fortunately, I was only trialling the software so there was nothing important locked away but I write this as a warning.
Let me see if I understand correctly.
"The problem is the screen goes all funny at boot time (splits into 4 sqiggly screens) and then comes up. It was unable to create the pagefile as there is not yet a d drive. You have to use truecrypt to make the d drive by putting in the password, which makes sense since that's what keeps the data safe."
So, on boot up, you see sqiggly screens, and then the computer continues to boot. Or does it give an error about creating a D drive?
I am also confused as to why you are putting your paging file on the D drive, and why it needs to be encrypted.
I also found this on TrueCrypts website - http://www.truecrypt.org/third-party-projects/tctemp/
Caution: Moving the paging file to the TCTEMP volume is still experimental. It is known for the current TCTEMP version that a STOP error (blue screen) can occur during Windows shutdown after the paging file has been moved to the TCTEMP volume.
no error is mentioned, it just fails to create the paging file since the D drive isn't mounted and it never creates/uses it after that.
The machines boots fine, just without a paging file.
D drive needs to be encrypted to protect a client's data (they requested it). The paging file needs to be encrypted/disabled so that you can't steal ram swapped data from it by putting the hard disk in another machine and doing a recovery of the data buried in it.
In that case, I suggest encrypting the D drive as normal, move the page file back to the default location and use TCTemp to encrypt the page file. You should put the page file back to it's default location to avoid problems like the one you mention above.
