hempa Posted February 26, 2007 Report Share Posted February 26, 2007 Hello! i have two harddrives on my computer, one with linux and one that is empty.my problem is that when i boot with the xp install cd it cant find any of my harddrives. what can i do?? i really want to install xp Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted February 26, 2007 Report Share Posted February 26, 2007 It is my understanding that you 'should' install Windows before Linux.It is good practice to install Windows XP first since it does not have the level of customization that Linux does(XP has the nasty habit of taking the first partition it finds).these may help:http://www.geocities.com/epark/linux/grub-w2k-HOWTO.htmlhttp://www.highlandsun.com/hyc/linuxboot.html Quote Link to comment Share on other sites More sharing options...
hempa Posted February 26, 2007 Author Report Share Posted February 26, 2007 It is my understanding that you 'should' install Windows before Linux.It is good practice to install Windows XP first since it does not have the level of customization that Linux does(XP has the nasty habit of taking the first partition it finds).these may help:http://www.geocities.com/epark/linux/grub-w2k-HOWTO.htmlhttp://www.highlandsun.com/hyc/linuxboot.htmlMy problem is that i dont allready have windows installed on any of the harddrives. and the installation cd cant find any of my harddrives. so i really need to know how to make my empty harddrive visible for the Xp installation cd Quote Link to comment Share on other sites More sharing options...
rong Posted February 26, 2007 Report Share Posted February 26, 2007 Don't know anything about Linux, but would it work if you disabled the drive with Linux inside the case and then installed windows on the other hard drive, then connect the Linux hard drive back up. Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted February 26, 2007 Report Share Posted February 26, 2007 You can, as rong says unplug the Linux drive and install Windows as normal. You may need to re-install GRUB or LILO so you can boot into both. Quote Link to comment Share on other sites More sharing options...
jason.b.c Posted February 26, 2007 Report Share Posted February 26, 2007 You can, as rong says unplug the Linux drive and install Windows as normal. You may need to re-install GRUB or LILO so you can boot into both.Oh man ..! , Who use's LILO anymore...??But seriously , Yea you would have to remove your linux hard drive and then install windows on the other...Make sure you put the linux drive back in as MASTER and the Windows drive has to be SLAVE...!It isn't nessasary to re-install Grub , Just add windows to the grub menu.list.....# Generated by jiffyboot version 9.1. If this file is edited, the# system will stop modifying it. To allow the system to resume# management of this file, remove it and run /sbin/jiffyboot#default=0timeout=10color cyan/green magenta/greensplashimage=/boot/grub/bootsplash.xpm.gzinstructions Use the %c and %c keys to select which entry is highlighted.timeout_message Entry %d will be booted automatically in %d seconds.# hda2, boot entrytitle Freespire Ver. 1.0.13root (hd0,1)kernel /boot/vmlinuz-2.6.14-gratis root=/dev/ide/host0/bus0/target0/lun0/part2 rootdev=0x0302 ramdisk=35392 Diagnostics video=vesafb:nomtrr jiffymount=noatime resume2=swap:/dev/hda2:0x44000 vga=0x311 splash=silentinitrd /boot/initrd-2.6.14-gratis.gz# hda2, diagnostic boot entry of /dev/ide/host0/bus0/target0/lun0/part2title Diagnosticsroot (hd0,1)kernel /boot/vmlinuz-2.6.14-gratis noresume2 single Diagnostics splash=0 root=/dev/ide/host0/bus0/target0/lun0/part2 rootdev=0x0302 ramdisk=35392 Diagnostics video=vesafb:nomtrr jiffymount=noatime resume2=swap:/dev/hda2:0x44000initrd /boot/initrd-2.6.14-gratis.gz# hda2, redetect boot entry of /dev/ide/host0/bus0/target0/lun0/part2title Redetectroot (hd0,1)kernel /boot/vmlinuz-2.6.14-gratis noresume2 redetect splash=0 root=/dev/ide/host0/bus0/target0/lun0/part2 rootdev=0x0302 ramdisk=35392 Diagnostics video=vesafb:nomtrr jiffymount=noatime resume2=swap:/dev/hda2:0x44000initrd /boot/initrd-2.6.14-gratis.gz#hda3, boot entrytitle XFCE Puppyroot (hd0,2)kernel (hd0,2)/boot/vmlinuz root=/dev/hda3 ro splash=silenttitle Advanced Menuconfigfile (hd0,1)/boot/grub/advanced-normal.lstIs what a boot menu looks like... Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted February 27, 2007 Report Share Posted February 27, 2007 You can also use, GAG - http://gag.sourceforge.net/ Quote Link to comment Share on other sites More sharing options...
