Intervideo winDVD creator problems...
This has never happened before....when I add a file onto the directory and play it, it plays fine....but when i drag it onto the timeline, the thumbnail turns upside down and plays upside down...this shows how the dvd will be created...anyone know how to fix this? it doesnt look like i changed any properties.....
this is a recent development....system restore? i wont restore my system just cause of this...I used Nero...it works well, but I would still like to know how to fix this problem...
What is the problem with using System Restore? You won't loose any e mails etc.
