susan Posted March 14, 2007 Report Share Posted March 14, 2007 HiI have this "system hangs frequently" problem in my office. We have 7 systems in our LAN.Our configuration is:OS - Windows 2000 Professional IE - 6.0 with SP1Usually we will all use, IE, Mozilla, MS-Office applications, Outlook express. Ans some softwares for our official purpose.We cannot analyse, why the problem arises...but all our systems hangs atleast 2 times and maximim 5-6 times.Can anyone please suggest me, what might be the problem.Awaiting for your response.Susan Quote Link to comment Share on other sites More sharing options...
-pops- Posted March 14, 2007 Report Share Posted March 14, 2007 Hello Susan and welcome to Windows Forum.Can you explain a little more about what happens (or doesn't happen) when the system "hangs"? Is this one machine or all seven? Does it shut down? Stop responding? Do you get a blue screen?Is there anything in the Event Viewer that might give a clue? Quote Link to comment Share on other sites More sharing options...
susan Posted March 14, 2007 Author Report Share Posted March 14, 2007 hi,We face the problem in all our 7 systems. If we get that problem, we cannot switch to other windows which are already open and also not able to see Task Manager when we do Alt+Ctrl+Del.Some times very slowly, we are able to restart it, after closong one by one windows. Some other times, we need to switch off the CPU directly.I dont get a blue screen.Hope this information are useful to analyse the issue.Susan Quote Link to comment Share on other sites More sharing options...
-pops- Posted March 14, 2007 Report Share Posted March 14, 2007 Any records in the Event Viewer?(Right click My Computer, click on Manage and then Event Viewer - there will be three or four sections, Application is the one that will give most information for this. Look for red crosses of yellow warning signs) Quote Link to comment Share on other sites More sharing options...
susan Posted March 14, 2007 Author Report Share Posted March 14, 2007 Hi,Yes, I saw it. We have many Yello warnings (Antivirus, Eventsystem, Loadperf etc) and Red errors (Internet Exporer, rasctrs).But i checked this in systems which hanged today. There is no error or warning data in Event viewer, in todays date. All are only Blue information things in todays date.Expecting a reply from you POPS.Thanks Quote Link to comment Share on other sites More sharing options...
susan Posted March 14, 2007 Author Report Share Posted March 14, 2007 Forgot to tell you..I get three Event viewer errors. Application, Secutiry and System errors. And data are there in Application and System errors.In system, Red Errors are there for DCOM, Service control manager, RemoteAccess, Rasman etc etc and Yello warnings for Print, Savrt. Quote Link to comment Share on other sites More sharing options...
-pops- Posted March 14, 2007 Report Share Posted March 14, 2007 You do seem to have a lot of errors reported there. Whilst I feel that individually they may not cause the hangings you are experiencing, the combination of errors may do.I'm not a W2K expert but the first approach I would try is to check the system files - these may assist:http://support.microsoft.com/kb/222193http://support.microsoft.com/kb/222471 Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted March 14, 2007 Report Share Posted March 14, 2007 If it is occuring on all computers, I would first assume a network problem. How is your LAN setup? Quote Link to comment Share on other sites More sharing options...
