Arek Posted April 5, 2007 Report Share Posted April 5, 2007 I tried to connect a secound HD by a USB connection which had always worked, it is not recongnized by Windows or Linux anyomore? I used it as a secoundary hard drive. Please help :( I'm guessing I'm missing some kind of driver since I recently reseted both of my hard drives and installed Windows home edition and Linux Ubuntu. Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted April 5, 2007 Report Share Posted April 5, 2007 Could you clarify a few things, You have an external USB hard drive that will not connect.And have you done fresh installs of Windows and Linux, I ask because Windows and Ubuntu should mount the USB drive automatically. Quote Link to comment Share on other sites More sharing options...
Arek Posted April 5, 2007 Author Report Share Posted April 5, 2007 Yes that is true. I have done this previiosly and it had worked before. Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted April 5, 2007 Report Share Posted April 5, 2007 Can you try the USB drive on another computer, to see if it is at fault, also have you got any other USB devices to try out, to see if they are mounted Quote Link to comment Share on other sites More sharing options...
Arek Posted April 5, 2007 Author Report Share Posted April 5, 2007 Yes. The HD works on my bro's computer. I'll also try to use a webcamera. In 2 min. I'll be done. Quote Link to comment Share on other sites More sharing options...
Arek Posted April 5, 2007 Author Report Share Posted April 5, 2007 I tried the webcamera which works, the HD works fine on my brothers computer. Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted April 5, 2007 Report Share Posted April 5, 2007 Sorry I am out of ideas, the fact that it would not mount in Widows or Ubuntu made me think it was a faulty drive, but as it works on your brothers computer thats me shot down in flames. In Ubuntu you could give this a try.http://www.linuxquestions.org/questions/sh...ad.php?t=201441 Quote Link to comment Share on other sites More sharing options...
Arek Posted April 5, 2007 Author Report Share Posted April 5, 2007 thanks for tring. ;) Quote Link to comment Share on other sites More sharing options...
-pops- Posted April 6, 2007 Report Share Posted April 6, 2007 Is the USB drive seen in Disk Management?(RIGHT click on My Computer, click on Manage -> Disk Management) Quote Link to comment Share on other sites More sharing options...
Arek Posted April 6, 2007 Author Report Share Posted April 6, 2007 Yes. I had tried that. It sees my 3 partitions. NTFS is for Windows. The other 2 are used for Linux. I can recongnize this by counting the GB's. Quote Link to comment Share on other sites More sharing options...
