Panarchy Posted April 15, 2007 Report Share Posted April 15, 2007 HELP!My dell monitor (Don't know the model number) isn't working!It was working fine on my PC, then I needed to fix another so I plugged that in (XP old) and it worked fine, fixed the problem, now my monitor doesn't work on my PC (vista)!Help please!This is really annoying.Panarchy Link to comment Share on other sites More sharing options...
-pops- Posted April 15, 2007 Report Share Posted April 15, 2007 First:Check that it is connected properly. Check that the connector does not have any damaged or bent pins.Check there is no damage to the cable.Try the monitor with another machine. Link to comment Share on other sites More sharing options...
Panarchy Posted April 15, 2007 Author Report Share Posted April 15, 2007 As I have stated, the monitor works fine with my grandma's old PC and it was working on mine until I used it on the old one, now it aint working on mine.I get this error message;In power Save ModePress any key on keyboard or move mouseWhat do I do?Of course I have tried the obvious (pressing a key and moving the mouse)Please help!Panarchy Link to comment Share on other sites More sharing options...
-pops- Posted April 15, 2007 Report Share Posted April 15, 2007 Could it be the machine rather than the monitor? Link to comment Share on other sites More sharing options...
Panarchy Posted April 15, 2007 Author Report Share Posted April 15, 2007 Maybe, I don't know. I am thinking about buying a 21 or 22 inch monitor (I am using a 17''), but there is no point doing so if that won't work.Please help,Panarchy Link to comment Share on other sites More sharing options...
Panarchy Posted April 15, 2007 Author Report Share Posted April 15, 2007 ^Actually, they are too expensive. So please help me fix my monitor. Link to comment Share on other sites More sharing options...
-pops- Posted April 15, 2007 Report Share Posted April 15, 2007 Can you borrow another monitor to test your machine?Other than that, I'm stuck. Link to comment Share on other sites More sharing options...
Panarchy Posted April 15, 2007 Author Report Share Posted April 15, 2007 Got it to work! I will close this topic now. Link to comment Share on other sites More sharing options...
